esp32
esp32 [2018/01/02 00:49] – [ESP-WROOM-32] 88.164.131.165 | esp32 [2024/06/09 18:09] (Version actuelle) – [Quel micro ?] jp | ||
- | L' | + | L' |
* S' | * S' | ||
- | * etc ... | + | * etc. |
+ | | ESP32-C2 | ||
+ | | ESP32-C3 | ||
+ | | ESP32-C5 | ||
+ | | ESP32-C6 | ||
+ | | ESP32-C61 | ||
+ | | ESP32-H2 | ||
+ | | ESP32-S2 | ||
+ | | ESP32-S3 | ||
+ | Sources: | ||
+ | * https:// | ||
+ | * https:// | ||
Ligne 42: | Ligne 75: | ||
+ | ==== PINOUT ==== | ||
Ligne 53: | Ligne 91: | ||
==== Installation de l' | ==== Installation de l' | ||
[[https:// | [[https:// | ||
+ | * Installer l' | ||
+ | * Télécharger l' | ||
+ | * Deziper l' | ||
+ | * L' | ||
+ | * Démarrer l' | ||
+ | pinMode(2, OUTPUT); | ||
+ | digitalWrite(2, | ||
+ | delay(200); | ||
+ | delay(800); | ||
+ | #include < | ||
+ | #include < | ||
+ | WiFiUDP udp; | ||
+ | void setup(){ | ||
+ | void loop(){ | ||
+ | if(connected){ | ||
+ | //Send a packet | ||
+ | udp.printf(" | ||
+ | udp.endPacket(); | ||
+ | //Wait for 1 second | ||
+ | delay(1000); | ||
+ | Serial.println(" | ||
+ | // delete old config | ||
+ | WiFi.begin(ssid, | ||
+ | //wifi event handler | ||
+ | switch(event) { | ||
+ | //When connected set | ||
+ | Serial.print(" | ||
+ | connected = true; | ||
+ | connected = false; | ||
+ | L' | ||
Ligne 60: | Ligne 237: | ||
esp32.1514850555.txt.gz · Dernière modification : 2018/01/02 00:49 de 88.164.131.165
