esp32
esp32 [2018/01/01 23:14] – [ESP-WROOM-32] 88.164.131.165 | esp32 [2024/06/09 15:53] – [Quel micro ?] 82.64.110.100 | ||
Ligne 10: | Ligne 10: | ||
* S' | * S' | ||
- | * etc ... | + | * etc. |
+ | Pour résumer : | ||
+ | ESP32 : Première série maintenant remplacée mais toujours largement utilisée | ||
+ | ESP32-Sx : Remplacement des ESP32 | ||
+ | ESP32-Cx : Moins performants que les ESP32-Sx mais aussi moins cher. | ||
+ | | ESP32-C2 | ||
+ | | ESP32-C3 | ||
+ | | ESP32-C6 | ||
+ | | ESP32-C61 | ||
+ | | ESP32-C5 | ||
+ | | ESP32-H2 | ||
+ | | ESP32-S2 | ||
+ | | ESP32-S3 | ||
+ | https:// | ||
Ligne 42: | Ligne 66: | ||
+ | ==== PINOUT ==== | ||
Ligne 51: | Ligne 80: | ||
- | ==== ESP-WROOM-32 | + | ==== Installation de l' |
[[https:// | [[https:// | ||
+ | * Installer l' | ||
+ | * Télécharger l' | ||
+ | * Deziper l' | ||
+ | * L' | ||
+ | * Démarrer l' | ||
+ | pinMode(2, OUTPUT); | ||
+ | digitalWrite(2, | ||
+ | delay(200); | ||
+ | delay(800); | ||
+ | #include < | ||
+ | #include < | ||
+ | WiFiUDP udp; | ||
+ | void setup(){ | ||
+ | void loop(){ | ||
+ | if(connected){ | ||
+ | //Send a packet | ||
+ | udp.printf(" | ||
+ | udp.endPacket(); | ||
+ | //Wait for 1 second | ||
+ | delay(1000); | ||
+ | Serial.println(" | ||
+ | // delete old config | ||
+ | WiFi.begin(ssid, | ||
+ | //wifi event handler | ||
+ | switch(event) { | ||
+ | //When connected set | ||
+ | Serial.print(" | ||
+ | connected = true; | ||
+ | connected = false; | ||
+ | L' | ||
Ligne 60: | Ligne 228: | ||
