PWM, I2S, IR
void setup() { // put your setup code here, to run once: pinMode(2, OUTPUT); // set pin to input } void loop() { // put your main code here, to run repeatedly: digitalWrite(2, HIGH); // sets the LED on delay(200); // waits for a second digitalWrite(2, LOW); // sets the LED off delay(800); }
/* * This sketch sends random data over UDP on a ESP32 device * */ #include <WiFi.h> #include <WiFiUdp.h> // WiFi network name and password: const char * networkName = "**your-ssid**"; const char * networkPswd = "**your-password**"; //IP address to send UDP data to: // either use the ip address of the server or // a network broadcast address const char * udpAddress = "**192.168.1.10**"; const int udpPort = 2205; //Are we currently connected? boolean connected = false; //The udp library class WiFiUDP udp; void setup(){ // Initilize hardware serial: Serial.begin(115200); //Connect to the WiFi network connectToWiFi(networkName, networkPswd); } void loop(){ //only send data when connected if(connected){ //Send a packet udp.beginPacket(udpAddress,udpPort); udp.printf("Seconds since boot: %u", millis()/1000); udp.endPacket(); } //Wait for 1 second delay(1000); } void connectToWiFi(const char * ssid, const char * pwd){ Serial.println("Connecting to WiFi network: " + String(ssid)); // delete old config WiFi.disconnect(true); //register event handler WiFi.onEvent(WiFiEvent); //Initiate connection WiFi.begin(ssid, pwd); Serial.println("Waiting for WIFI connection..."); } //wifi event handler void WiFiEvent(WiFiEvent_t event){ switch(event) { case SYSTEM_EVENT_STA_GOT_IP: //When connected set Serial.print("WiFi connected! IP address: "); Serial.println(WiFi.localIP()); //initializes the UDP state //This initializes the transfer buffer udp.begin(WiFi.localIP(),udpPort); connected = true; break; case SYSTEM_EVENT_STA_DISCONNECTED: Serial.println("WiFi lost connection"); connected = false; break; } }
