ampoules_connectees_-_philips_hue_et_osram_ligthify [2017/12/06 16:12] – modification externe 127.0.0.1 | ampoules_connectees_-_philips_hue_et_osram_ligthify [2018/03/09 10:21] – [Récupération de la liste des ampoules] 88.164.131.165 | ||
Ligne 206: | Ligne 206: | ||
+ | ==== Récupération de la liste des ampoules ==== | ||
+ | <code csharp> | ||
+ | public List< | ||
+ | string url = @" | ||
+ | bool on = false; | ||
+ | int bri = 0; | ||
+ | string alert = ""; | ||
+ | string type = ""; | ||
+ | string name = ""; | ||
+ | string modelid = ""; | ||
+ | string uniqueid= ""; | ||
+ | Lumiere.name = name; | ||
+ | Lumiere.bri = bri; | ||
+ | Lumiere.type = type; | ||
+ | return Devices; | ||
+ | ====Allume ou éteint une ampoule ==== | ||
+ | /// <param name=" | ||
+ | try | ||
+ | string data; | ||
+ | if (state == 1) | ||
+ | data = "{ \" | ||
+ | else | ||
+ | byte[] bytes; | ||
+ | catch (Exception ex) | ||
+ | return false; | ||
+ | return true; | ||
