Philips HUE et OSRAM Lightify
OSRAM Lightify
FAQ
Exemple application C#
La documentation de l'API : https://eu.lightify-api.org/ Inspiré du code : https://github.com/patrick-dmxc/OsramLightify/blob/master/OsramLightify/Osram/Lightify/OsramController.cs Class pour le decodage JSON : http://www.newtonsoft.com/json
Récupération d'un ticket
- |Ticket
//Le Token n'est valable que 15mn //user : le nom d'utilisateur de votre compte Osram //pass : votre mot de pass .... //serialnum : Le numéro de série qui apparait sur la passerelle OSR0xxxxxxx (Ne pas indiquer ce qui trouve apres le "-" OsramToken token = OsramController.GetOsramToken("user", "pass", "serialnum"); textBoxToken.Text = token.securityToken; textBoxUserID.Text = token.userId;
- |Class OsramToken
public class OsramToken { public string userId { get; set; } public string securityToken { get; set; } }
- |Class OsramController
public class OsramController { public static OsramToken GetOsramToken(string username, string password, string serialNumber) { string payload = "{\"username\" : \"" + username + "\",\"password\" : \"" + password + "\",\"serialNumber\" : \"" + serialNumber + "\"}"; string url = "https://eu.lightify-api.org/lightify/services/session"; var httpWebRequest = (HttpWebRequest)WebRequest.Create(url); httpWebRequest.UserAgent = "Lightify/1.0.5 CFNetwork/711.1.16 Darwin/14.0.0"; httpWebRequest.Method = "POST"; httpWebRequest.ContentType = "application/json"; using (var streamWriter = new StreamWriter(httpWebRequest.GetRequestStream())) { streamWriter.Write(payload); streamWriter.Flush(); streamWriter.Close(); } OsramToken os = new OsramToken(); var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse(); using (var streamReader = new StreamReader(httpResponse.GetResponseStream())) { var result = streamReader.ReadToEnd(); os = JsonConvert.DeserializeObject<OsramToken>(result); } return os; } public static List<OsramDevice> GetDevicesList(string token) { List<OsramDevice> Devices = new List<OsramDevice>(); string url = "https://eu.lightify-api.org/lightify/services/devices"; var httpWebRequest = (HttpWebRequest)WebRequest.Create(url); httpWebRequest.UserAgent = "Lightify/1.0.5 CFNetwork/711.1.16 Darwin/14.0.0"; httpWebRequest.Method = "GET"; httpWebRequest.ContentType = "application/json"; httpWebRequest.Headers.Add("authorization",token); var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse(); using (var streamReader = new StreamReader(httpResponse.GetResponseStream())) { var result = streamReader.ReadToEnd(); Devices = JsonConvert.DeserializeObject<List<OsramDevice>>(result); } return Devices; } public static string SenCommand(string token, string cmd) { string result = ""; string url = "https://eu.lightify-api.org/lightify/services/"+cmd; var httpWebRequest = (HttpWebRequest)WebRequest.Create(url); httpWebRequest.UserAgent = "Lightify/1.0.5 CFNetwork/711.1.16 Darwin/14.0.0"; httpWebRequest.Method = "GET"; httpWebRequest.ContentType = "application/json"; httpWebRequest.Headers.Add("authorization", token); var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse(); using (var streamReader = new StreamReader(httpResponse.GetResponseStream())) { result = streamReader.ReadToEnd(); } return result; } }
Récupération de la liste des équipements
- |Devices
- |Class Devices
public class OsramDevice { public int deviceId { get; set; } public string deviceType { get; set; } public string manufacturer { get; set; } public string modelName { get; set; } public string name { get; set; } public List<int> groupList { get; set; } public List<string> bmpClusters { get; set; } public bool online { get; set; } public bool on { get; set; } public float brightnessLevel { get; set; } public float hue { get; set; } public float saturation { get; set; } public int temperature { get; set; } public string firmwareVersion { get; set; } public string color { get; set; } }
Envoi de commandes à un équipement
Toutes les commandes doivent faire référence à un ID d'équipement récupéré avec la liste des devices
- |Class Devices
private void buttonTurnOff_Click(object sender, EventArgs e) { string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&time=" + numericUpDownTime.Value.ToString() + "&onoff=0"); } private void buttonTurnOn_Click(object sender, EventArgs e) { string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&level=" + (numericUpDownLevel.Value / 100).ToString().Replace(",", ".") + "&time=" + numericUpDownTime.Value.ToString() + "&onoff=1"); } private void buttonChangeColor_Click(object sender, EventArgs e) { string color = labelColor.Text.Replace("#", ""); string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&time=" + numericUpDownTime.Value.ToString() + "&color="+labelColor.Text.Replace("#","")); } private void buttonChangeLevel_Click(object sender, EventArgs e) { string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&level=" + (numericUpDownLevel.Value / 100).ToString().Replace(",", ".") + "&time=" + numericUpDownTime.Value.ToString()); } private void buttonChangeTemperature_Click(object sender, EventArgs e) { string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&time=" + numericUpDownTime.Value.ToString() + "&ctemp="+numericUpDownTemperature.Value.ToString()); }
Philips HUE
FAQ
Récupération de la liste des ampoules
- csharp |HueDevice
public class HueDevice { public int deviceId { get; set; } public string deviceType { get; set; } public string name { get; set; } public bool online { get; set; } public int bri { get; set; } public string alert { get; set; } public bool reachable { get; set; } public string type { get; set; } public string modelid { get; set; } public string manufacturername { get; set; } public string uniqueid { get; set; } public string swversion { get; set; } }
public List<HueDevice> GetDevicesList() { Devices = new List<HueDevice>(); string url = @"http://" + ip + "/api/" + username + "/lights"; var httpWebRequest = (HttpWebRequest)WebRequest.Create(url); httpWebRequest.Method = "GET"; httpWebRequest.ContentType = "application/json"; var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse(); using (var streamReader = new StreamReader(httpResponse.GetResponseStream())) { var result = streamReader.ReadToEnd(); dynamic response = JsonConvert.DeserializeObject(result); foreach (var item in response) { string id = item.Name; bool on = false; int bri = 0; string alert = ""; bool reachable = false; string type = ""; string name = ""; string modelid = ""; string manufacturername = ""; string uniqueid= ""; string swversion= ""; foreach (var parameters in item) { if (parameters.state != null) { if (parameters.state.on != null) on = (bool)parameters.state.on; if (parameters.state.bri != null) bri = (int)parameters.state.bri; if (parameters.state.none != null) alert = (string)parameters.state.alert; if (parameters.state.reachable != null) reachable = (bool)parameters.state.reachable; } if (parameters.type != null) type = (string)parameters.type; if (parameters.name != null) name = (string)parameters.name; if (parameters.modelid != null) modelid = (string)parameters.modelid; if (parameters.manufacturername != null) manufacturername = (string)parameters.manufacturername; if (parameters.uniqueid != null) uniqueid = (string)parameters.uniqueid; if (parameters.swversion != null) swversion = (string)parameters.swversion; } Hue.HueDevice Lumiere = new HueDevice(); Lumiere.deviceId = Convert.ToInt32(id); Lumiere.name = name; Lumiere.online = reachable; Lumiere.bri = bri; Lumiere.alert = alert; Lumiere.reachable = reachable; Lumiere.type = type; Lumiere.modelid = modelid; Lumiere.manufacturername = manufacturername; Lumiere.uniqueid = uniqueid; Lumiere.swversion = swversion; Devices.Add(Lumiere); } return Devices; } }
Allume ou éteint une ampoule
/// <summary> /// Allume ou éteint l'ampoule avec l'id spécifié /// </summary> /// <param name="id"></param> /// <param name="state"></param> internal bool SetState(string id, int state) { try { string data; if (state == 1) data = "{ \"on\":true}"; else data = "{ \"on\":false}"; byte[] bytes; bytes = System.Text.Encoding.UTF8.GetBytes(data); string url = @"http://" + ip + "/api/" + username + "/lights/" + id + "/state"; var httpWebRequest = (HttpWebRequest)WebRequest.Create(url); httpWebRequest.Method = "PUT"; httpWebRequest.ContentType = "application/json"; httpWebRequest.ContentLength = bytes.Length; Stream requestStream = httpWebRequest.GetRequestStream(); requestStream.Write(bytes, 0, bytes.Length); requestStream.Close(); var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse(); using (var streamReader = new StreamReader(httpResponse.GetResponseStream())) { var result = streamReader.ReadToEnd(); dynamic response = JsonConvert.DeserializeObject(result); } } catch (Exception ex) { return false; } return true; }
