ESP32 ARDUINO
- Prix faible ~5€ pour le module ~8€ pour une petite carte de developpement
- Intègre Bluetooth 4.2 - BLE Bluetooth low Energy
- Intègre un microcontrôleur 32 bits performants et de nombreux périphériques (ADC 12bit, DAC, 3xUART, PWM, I2C, SPI, etc …)
- etc …
Caractéristiques
CPU
- 448 kB ROM
- 520 kB SRAM
- 16 kB SRAM in RTC
- Power supply: 2.3V to 3.6V
PWM, I2S, IR
- Alimentation : 2.7 ~ 3.6V
- Courant max : 500 mA
WIFI
OS
- FreeRTOS
Brochage
PINOUT
ESP-WROOM-32
- Installer l'environnement ARDUINO : https://www.arduino.cc/en/Main/Software
- Télécharger l'add-on pour l'ESP32 : https://github.com/espressif/arduino-esp32
- Deziper l'add-on dans le répertoire : Mes Documents\Arduino\hardware\espressif\esp32
void setup() { // put your setup code here, to run once: pinMode(2, OUTPUT); // set pin to input } void loop() { // put your main code here, to run repeatedly: digitalWrite(2, HIGH); // sets the LED on delay(200); // waits for a second digitalWrite(2, LOW); // sets the LED off delay(800); }
Sketch exemples
Sketch transmission wifi
/* * This sketch sends random data over UDP on a ESP32 device * */ #include <WiFi.h> #include <WiFiUdp.h> // WiFi network name and password: const char * networkName = "**your-ssid**"; const char * networkPswd = "**your-password**"; //IP address to send UDP data to: // either use the ip address of the server or // a network broadcast address const char * udpAddress = "**192.168.1.10**"; const int udpPort = 2205; //Are we currently connected? boolean connected = false; //The udp library class WiFiUDP udp; void setup(){ // Initilize hardware serial: Serial.begin(115200); //Connect to the WiFi network connectToWiFi(networkName, networkPswd); } void loop(){ //only send data when connected if(connected){ //Send a packet udp.beginPacket(udpAddress,udpPort); udp.printf("Seconds since boot: %u", millis()/1000); udp.endPacket(); } //Wait for 1 second delay(1000); } void connectToWiFi(const char * ssid, const char * pwd){ Serial.println("Connecting to WiFi network: " + String(ssid)); // delete old config WiFi.disconnect(true); //register event handler WiFi.onEvent(WiFiEvent); //Initiate connection WiFi.begin(ssid, pwd); Serial.println("Waiting for WIFI connection..."); } //wifi event handler void WiFiEvent(WiFiEvent_t event){ switch(event) { case SYSTEM_EVENT_STA_GOT_IP: //When connected set Serial.print("WiFi connected! IP address: "); Serial.println(WiFi.localIP()); //initializes the UDP state //This initializes the transfer buffer udp.begin(WiFi.localIP(),udpPort); connected = true; break; case SYSTEM_EVENT_STA_DISCONNECTED: Serial.println("WiFi lost connection"); connected = false; break; } }
