esp32 [2018/01/02 22:12] 88.164.131.165 [Installation de l'environnement de développement] |
esp32 [2020/12/31 10:48] 91.175.66.34 [ESP32 ARDUINO] |
Ligne 10: | Ligne 10: | ||
- | * etc ... | + | * etc. |
Ligne 42: | Ligne 42: | ||
+ | ==== PINOUT ==== | ||
Ligne 99: | Ligne 104: | ||
</code> | </code> | ||
+ | <code> | ||
+ | #include <WiFi.h> | ||
+ | #include <WiFiUdp.h> | ||
+ | WiFiUDP udp; | ||
+ | void setup(){ | ||
+ | void loop(){ | ||
+ | if(connected){ | ||
+ | //Send a packet | ||
+ | udp.endPacket(); | ||
+ | //Wait for 1 second | ||
+ | delay(1000); | ||
+ | // delete old config | ||
+ | //wifi event handler | ||
+ | switch(event) { | ||
+ | //When connected set | ||
+ | connected = true; | ||
+ | connected = false; | ||
Ligne 106: | Ligne 204: | ||
