cms [2022/12/19 10:42] 37.58.249.7 [Valeur] |
cms [2022/12/19 14:27] 37.58.249.7 [Les boîtiers] |
Ligne 65: | Ligne 65: | ||
10R = 10Ω | 10R = 10Ω | ||
+ | B = 101 | ||
+ | C = 102 | ||
+ | D = 103 | ||
+ | //By Lili// | ||
Ligne 85: | Ligne 131: | ||
+ | 2917 [7343 Metric] | ||
+ | === Cas RARE en dépannage === | ||
+ | By Lili | ||
==== Valeur ==== | ==== Valeur ==== |
