cms [2022/12/19 10:40] 37.58.249.7 [Valeur] |
cms [2022/12/19 14:27] 37.58.249.7 [Les boîtiers] |
Ligne 65: | Ligne 65: | ||
10R = 10Ω | 10R = 10Ω | ||
+ | B = 101 | ||
+ | C = 102 | ||
+ | D = 103 | ||
+ | //By Lili// | ||
Ligne 85: | Ligne 131: | ||
+ | 2917 [7343 Metric] | ||
+ | === Cas RARE en dépannage === | ||
+ | By Lili | ||
==== Valeur ==== | ==== Valeur ==== | ||
Ligne 124: | Ligne 199: | ||
- | ^ Tension (V) | 4.0 | 6.3 | 10 | 16 | 20 | 25 | 35 | 50 | 100 | | + | ^ Tension (V) | 4.0 | 6.3 | 10 | 16 | 20 | 25 | 35 | 50 | 63 | 100 | |
- | ^ Code | G | j | A | C | D | E | V | H | 2A | | + | ^ Code | G | j | A | C | D | E | V | H | J | 2A | |
+ | By Lili | ||
===== Diodes ===== | ===== Diodes ===== |
