transmission_433mhz
transmission_433mhz [2018/04/30 08:52] – 88.164.131.165 | transmission_433mhz [2018/04/30 10:08] – [Utilisation] 88.164.131.165 | ||
Ligne 3: | Ligne 3: | ||
===== Module Arduino low cost ===== | ===== Module Arduino low cost ===== | ||
===== Si4432 ===== | ===== Si4432 ===== | ||
Ligne 28: | Ligne 30: | ||
+ | ==== Outil ==== | ||
+ | J' | ||
+ | * Lancer Zadig.exe | ||
+ | * Démarrer SDRSharp | ||
+ | Exemple d' | ||
+ | SDRSharp | ||
+ | Il est possible d' | ||
+ | Trames reçues : | ||
+ | Détail d'une trame : | ||
+ | Mesure des temps : | ||
+ | <code csharp> | ||
+ | #include " | ||
+ | pinMode(4, OUTPUT); | ||
+ | rfManager.send(code, | ||
+ | //Attend 10 ms | ||
+ | delay(10); | ||
+ | #include " | ||
+ | RfManager:: | ||
+ | void RfManager:: | ||
+ | if (code[i] == 1) | ||
+ | transmit(1); | ||
+ | else | ||
+ | transmit(0); | ||
+ | TransmitPin = pin; | ||
+ | pinMode(TransmitPin, | ||
+ | if (bit == 1) | ||
+ | else | ||
+ | #ifndef _RfManager_h | ||
+ | #define _RfManager_h | ||
+ | #include " | ||
+ | #endif | ||
+ | #include < | ||
+ | class RfManager { | ||
+ | public: | ||
+ | RfManager(); | ||
+ | private: | ||
+ | #endif | ||
