transmission_433mhz
transmission_433mhz [2018/04/30 08:52] – 88.164.131.165 | transmission_433mhz [2018/04/30 09:55] – [Utilisation] 88.164.131.165 | ||
Ligne 3: | Ligne 3: | ||
===== Module Arduino low cost ===== | ===== Module Arduino low cost ===== | ||
===== Si4432 ===== | ===== Si4432 ===== | ||
Ligne 28: | Ligne 30: | ||
+ | ==== Outil ==== | ||
+ | J' | ||
+ | * Lancer Zadig.exe | ||
+ | * Démarrer SDRSharp | ||
+ | Exemple d' | ||
+ | SDRSharp | ||
+ | Il est possible d' | ||
+ | Trames reçues : | ||
+ | Détail d'une trame : | ||
+ | Mesure des temps : | ||
