memo_des_indispensables
memo_des_indispensables [2015/04/17 22:52] – [OpenFileDialog] 82.228.9.53 | memo_des_indispensables [2015/04/25 20:06] – [Selectionner un répertoire] 82.228.9.53 | ||
Ligne 6: | Ligne 6: | ||
==== OpenFileDialog ==== | ==== OpenFileDialog ==== | ||
<code csharp |OpenFileDialog> | <code csharp |OpenFileDialog> | ||
+ | OpenFileDialog openFileDialogModele = new OpenFileDialog(); | ||
+ | openFileDialogModele.Filter = "Text files (*.txt)|*.txt|All files (*.*)|*.*"; | ||
+ | openFileDialogModele.InitialDirectory = Environment.GetFolderPath(Environment.SpecialFolder.DesktopDirectory); | ||
- | OpenFileDialog openFileDialogModele = new OpenFileDialog(); | + | DialogResult result = openFileDialogModele.ShowDialog(); |
- | openFileDialogModele.Filter = "Text files (*.txt)|*.txt|All files (*.*)|*.*"; | + | if (result == DialogResult.OK) |
- | openFileDialogModele.InitialDirectory = Environment.GetFolderPath(Environment.SpecialFolder.DesktopDirectory); | + | { |
- | + | textBoxModele.Text = openFileDialogModele.FileName; | |
- | if (result == DialogResult.OK) | + | |
- | textBoxModele.Text = openFileDialogModele.FileName; | + | |
+ | ==== Lecture d'un fichier texte ==== | ||
+ | <code csharp |OpenFileDialog> | ||
+ | System.IO.StreamReader file = new System.IO.StreamReader(textBoxIdModele.Text); | ||
+ | string Text = file.ReadToEnd(); | ||
+ | file.Close(); | ||
==== Lecture d'un fichier texte ligne par ligne ==== | ==== Lecture d'un fichier texte ligne par ligne ==== | ||
- | | + | List< |
- | | + | string line; |
- | System.IO.StreamReader file = new System.IO.StreamReader(@" | + | System.IO.StreamReader file = new System.IO.StreamReader(@" |
- | while ((line = file.ReadLine()) != null) | + | while ((line = file.ReadLine()) != null) |
- | lines.Add(line); | + | |
+ | ==== Ecriture d'un fichier texte ==== | ||
+ | <code csharp |WriteAllText> | ||
+ | System.IO.File.WriteAllText(@" | ||
+ | ==== Selectionner un répertoire ==== | ||
+ | <code csharp |FolderBrowserDialog> | ||
+ | string Path; | ||
+ | FolderBrowserDialog folderBrowserDialog = new FolderBrowserDialog(); | ||
+ | folderBrowserDialog.RootFolder = Environment.SpecialFolder.DesktopDirectory; | ||
+ | if (folderBrowserDialog.ShowDialog() == DialogResult.OK) | ||
+ | Path = folderBrowserDialog.SelectedPath; | ||
+ | ===== Événements ===== | ||
+ | Vous avez un objet qui doit vous renvoyer une information. Exemple un client doit se connecter à un serveur et vous souhaitez recupérer l' | ||
+ | Voici un petit exemple. | ||
+ | La premiere chose à faire est dans la classe de votre objet de créer le ou les évenements. | ||
+ | Cette événement renverra un argument herité de EventArgs. Il est possible de passer n' | ||
+ | <code csharp |Exemple d' | ||
+ | class Client | ||
+ | public event EventHandler< | ||
+ | protected virtual void OnClientConnected(ConnectedEventArgs e) | ||
+ | if (ClientConneted != null) ClientConneted(this, | ||
+ | public Client() | ||
+ | public void Connect() | ||
+ | // Si connecté : | ||
+ | OnClientConnected(new ConnectedEventArgs(" | ||
+ | //Classe de l' | ||
+ | public class ConnectedEventArgs : EventArgs | ||
+ | internal string m_msg; | ||
+ | internal int m_val; | ||
+ | public ConnectedEventArgs(string msg, int val) | ||
+ | m_msg = msg; | ||
+ | m_val = val; | ||
+ | Une fois que vous avez créé votre événement dans votre objet, il faut que votre application s' | ||
+ | Client clt = new Client(); | ||
+ | public Form1() | ||
+ | InitializeComponent(); | ||
+ | clt.ClientConneted += new EventHandler< | ||
+ | //Lancement de la précudure de connexion qui déclenchera l' | ||
+ | clt.Connect(); | ||
+ | /// Methode qui sera executé au déclenchement de l' | ||
+ | /// <param name=" | ||
+ | private void clt_ClientConneted(object sender, ConnectedEventArgs e) | ||
+ | MessageBox.Show(" | ||
memo_des_indispensables.txt · Dernière modification : 2017/12/06 16:13 de 127.0.0.1
