esp32
esp32 [2017/12/16 01:01] – [Liens utiles] 88.164.131.165 | esp32 [2024/06/09 12:04] – [ESP32 ARDUINO] 82.64.110.100 | ||
- | * Intègre Bluetooth 4.2 - BLE Bluetooth low Energy | + | * Intègre Bluetooth |
* S' | * S' | ||
+ | * etc. | ||
+ | | ESP32-C3 | ||
+ | | ESP32-C6 | ||
+ | | ESP32-H2 | ||
+ | | ESP32-C3 | ||
+ | | ESP32-C6 | ||
+ | https:// | ||
Ligne 41: | Ligne 52: | ||
+ | ==== PINOUT ==== | ||
Ligne 48: | Ligne 64: | ||
+ | [[https:// | ||
+ | * Installer l' | ||
+ | * Télécharger l' | ||
+ | * Deziper l' | ||
+ | * L' | ||
+ | * Démarrer l' | ||
+ | pinMode(2, OUTPUT); | ||
+ | digitalWrite(2, | ||
+ | delay(200); | ||
+ | delay(800); | ||
+ | #include < | ||
+ | #include < | ||
+ | WiFiUDP udp; | ||
+ | void setup(){ | ||
+ | void loop(){ | ||
+ | if(connected){ | ||
+ | //Send a packet | ||
+ | udp.printf(" | ||
+ | udp.endPacket(); | ||
+ | //Wait for 1 second | ||
+ | delay(1000); | ||
+ | Serial.println(" | ||
+ | // delete old config | ||
+ | WiFi.begin(ssid, | ||
+ | //wifi event handler | ||
+ | switch(event) { | ||
+ | //When connected set | ||
+ | Serial.print(" | ||
+ | connected = true; | ||
+ | connected = false; | ||
+ | L' | ||
Ligne 55: | Ligne 214: | ||
