esp32
esp32 [2017/12/15 23:13] – [OS] 88.164.131.165 | esp32 [2018/01/02 22:38] – [1er sketch de test - clignotement LED] 88.164.131.165 | ||
- | * Intègre Bluetooth 4.2 - BLE Bluetooth low Energy | + | * Intègre Bluetooth |
* S' | * S' | ||
+ | * etc ... | ||
Ligne 39: | Ligne 40: | ||
==== OS ==== | ==== OS ==== | ||
* FreeRTOS | * FreeRTOS | ||
+ | ===== Brochage ===== | ||
+ | [[https:// | ||
+ | * Installer l' | ||
+ | * Télécharger l' | ||
+ | * Deziper l' | ||
+ | * L' | ||
+ | * Démarrer l' | ||
+ | pinMode(2, OUTPUT); | ||
+ | digitalWrite(2, | ||
+ | delay(200); | ||
+ | delay(800); | ||
+ | #include < | ||
+ | #include < | ||
+ | WiFiUDP udp; | ||
+ | void setup(){ | ||
+ | void loop(){ | ||
+ | if(connected){ | ||
+ | //Send a packet | ||
+ | udp.printf(" | ||
+ | udp.endPacket(); | ||
+ | //Wait for 1 second | ||
+ | delay(1000); | ||
+ | Serial.println(" | ||
+ | // delete old config | ||
+ | WiFi.begin(ssid, | ||
+ | //wifi event handler | ||
+ | switch(event) { | ||
+ | //When connected set | ||
+ | Serial.print(" | ||
+ | connected = true; | ||
+ | connected = false; | ||
+ | L' | ||
Ligne 44: | Ligne 197: | ||
+ | * [[https:// | ||
