cms
cms [2022/12/19 10:39] – [Valeur] 37.58.249.7 | cms [2022/12/19 14:27] – [Les boîtiers] 37.58.249.7 | ||
Ligne 65: | Ligne 65: | ||
10R = 10Ω | 10R = 10Ω | ||
+ | X = 10-1, exemple : 66X = 47, | ||
+ | B = 101 | ||
+ | C = 102 | ||
+ | D = 103 | ||
+ | E = 104, exemple : 51E = 3320000 ohms = 3, | ||
+ | //By Lili// | ||
Ligne 85: | Ligne 131: | ||
- | Le côté " | + | Disponible pour des capacités de 0.1µF à 3300µF |
+ | Le côté " | ||
- | | + | 0402 [1005 Metric] |
- | | + | 0603 [1608 Metric] |
+ | 0905 [2414 Metric] | ||
+ | 1206 [3216 Metric] | ||
+ | 2917 [7343 Metric] | ||
+ | D' | ||
+ | === Cas RARE en dépannage === | ||
+ | {{:chimique.png? | ||
+ | Farnell : [[https:// | ||
+ | By Lili | ||
==== Valeur ==== | ==== Valeur ==== | ||
Ligne 124: | Ligne 199: | ||
- | ^ Tension (V) | 4.0 | 6.3 | 10 | 16 | 20 | 25 | 35 | 50 | 100 | | + | ^ Tension (V) | 4.0 | 6.3 | 10 | 16 | 20 | 25 | 35 | 50 |
- | ^ Code | G | | + | ^ Code | G | |
+ | By Lili | ||
===== Diodes ===== | ===== Diodes ===== |
cms.txt · Dernière modification : 2022/12/19 15:29 de 37.58.249.7
