ampoules_connectees_-_philips_hue_et_osram_ligthify
Philips HUE et OSRAM Lightify
OSRAM Lightify
FAQ
Exemple application C#
Récupération d'un ticket
|Ticket
            //Le Token n'est valable que 15mn
            //user : le nom d'utilisateur de votre compte Osram
            //pass : votre mot de pass ....
            //serialnum : Le numéro de série qui apparait sur la passerelle OSR0xxxxxxx (Ne pas indiquer ce qui trouve apres le "-"
            OsramToken token = OsramController.GetOsramToken("user", "pass", "serialnum");
            textBoxToken.Text = token.securityToken;
            textBoxUserID.Text = token.userId;
|Class OsramToken
    public class OsramToken
        public string userId { get; set; }
        public string securityToken { get; set; }
|Class OsramController
    public class OsramController
        public static OsramToken GetOsramToken(string username, string password, string serialNumber)
            string payload = "{\"username\" : \"" + username + "\",\"password\" : \"" + password + "\",\"serialNumber\" : \"" + serialNumber + "\"}";
            string url = "https://eu.lightify-api.org/lightify/services/session";
            var httpWebRequest = (HttpWebRequest)WebRequest.Create(url);
            httpWebRequest.UserAgent = "Lightify/1.0.5 CFNetwork/711.1.16 Darwin/14.0.0";
            httpWebRequest.Method = "POST";
            httpWebRequest.ContentType = "application/json";
            using (var streamWriter = new StreamWriter(httpWebRequest.GetRequestStream()))
                streamWriter.Write(payload);
                streamWriter.Flush();
                streamWriter.Close();
            OsramToken os = new OsramToken();
            var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse();
            using (var streamReader = new StreamReader(httpResponse.GetResponseStream()))
                var result = streamReader.ReadToEnd();
                os = JsonConvert.DeserializeObject<OsramToken>(result);
            return os;
        public static List<OsramDevice> GetDevicesList(string token)
            List<OsramDevice> Devices = new List<OsramDevice>();
            string url = "https://eu.lightify-api.org/lightify/services/devices";
            httpWebRequest.Method = "GET";
            httpWebRequest.Headers.Add("authorization",token);
                Devices = JsonConvert.DeserializeObject<List<OsramDevice>>(result);
            return Devices;
        public static string SenCommand(string token, string cmd)
            string result = "";
            string url = "https://eu.lightify-api.org/lightify/services/"+cmd;
            httpWebRequest.Headers.Add("authorization", token);
            return result;
Récupération de la liste des équipements
|Devices
|Class Devices
    public class OsramDevice
        public int deviceId { get; set; }
        public string deviceType { get; set; }
        public string manufacturer { get; set; }
        public string modelName { get; set; }
        public string name { get; set; }
        public List<int> groupList { get; set; }
        public List<string> bmpClusters { get; set; }
        public bool online { get; set; }
        public bool on { get; set; }
        public float brightnessLevel { get; set; }
        public float hue { get; set; }
        public float saturation { get; set; }
        public int temperature { get; set; }
        public string firmwareVersion { get; set; }
        public string color { get; set; }
Envoi de commandes à un équipement
Toutes les commandes doivent faire référence à un ID d'équipement récupéré avec la liste des devices
|Class Devices
        private void buttonTurnOff_Click(object sender, EventArgs e)
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&time=" + numericUpDownTime.Value.ToString() + "&onoff=0");
        private void buttonTurnOn_Click(object sender, EventArgs e)
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&level=" + (numericUpDownLevel.Value / 100).ToString().Replace(",", ".") + "&time=" + numericUpDownTime.Value.ToString() + "&onoff=1");
        private void buttonChangeColor_Click(object sender, EventArgs e)
            string color = labelColor.Text.Replace("#", "");
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&time=" + numericUpDownTime.Value.ToString() + "&color="+labelColor.Text.Replace("#",""));
        private void buttonChangeLevel_Click(object sender, EventArgs e)
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&level=" + (numericUpDownLevel.Value / 100).ToString().Replace(",", ".") + "&time=" + numericUpDownTime.Value.ToString());
        private void buttonChangeTemperature_Click(object sender, EventArgs e)
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&time=" + numericUpDownTime.Value.ToString() + "&ctemp="+numericUpDownTemperature.Value.ToString());
Philips HUE
FAQ
Récupération de la liste des ampoules
csharp |HueDevice
    public class HueDevice
        public int bri { get; set; }
        public string alert { get; set; }
        public bool reachable { get; set; }
        public string type { get; set; }
        public string modelid { get; set; }
        public string manufacturername { get; set; }
        public string uniqueid { get; set; }
        public string swversion { get; set; }
        public List<HueDevice> GetDevicesList()
           Devices = new List<HueDevice>();
            string url = @"http://" + ip + "/api/" + username + "/lights";
                dynamic response = JsonConvert.DeserializeObject(result);
                foreach (var item in response)
                    string id = item.Name;
                    bool on = false;
                    int bri = 0;
                    string alert = "";
                    bool reachable = false;
                    string type = "";
                    string name = "";
                    string modelid = "";
                    string manufacturername = "";
                    string uniqueid= "";
                    string swversion= "";
                    foreach (var parameters in item)
                        if (parameters.state != null)
                            if (parameters.state.on != null)
                                on = (bool)parameters.state.on;
                            if (parameters.state.bri != null)
                                bri = (int)parameters.state.bri;
                            if (parameters.state.none != null)
                                alert = (string)parameters.state.alert;
                            if (parameters.state.reachable != null)
                                reachable = (bool)parameters.state.reachable;
                        if (parameters.type != null)
                            type = (string)parameters.type;
                        if (parameters.name != null)
                            name = (string)parameters.name;
                        if (parameters.modelid != null)
                            modelid = (string)parameters.modelid;
                        if (parameters.manufacturername != null)
                            manufacturername = (string)parameters.manufacturername;
                        if (parameters.uniqueid != null)
                            uniqueid = (string)parameters.uniqueid;
                        if (parameters.swversion != null)
                            swversion = (string)parameters.swversion;
                    Hue.HueDevice Lumiere = new HueDevice();
                    Lumiere.deviceId = Convert.ToInt32(id);
                    Lumiere.name = name;
                    Lumiere.online = reachable;
                    Lumiere.bri = bri;
                    Lumiere.alert = alert;
                    Lumiere.reachable = reachable;
                    Lumiere.type = type;
                    Lumiere.modelid = modelid;
                    Lumiere.manufacturername = manufacturername;
                    Lumiere.uniqueid = uniqueid;
                    Lumiere.swversion = swversion;
                    Devices.Add(Lumiere);
                return Devices;
Allume ou éteint une ampoule
        /// <summary>
        /// Allume ou éteint l'ampoule avec l'id spécifié
        /// </summary>
        /// <param name="id"></param>
        /// <param name="state"></param>
        internal bool SetState(string id, int state)
            try
                string data;
                if (state == 1)
                    data = "{ \"on\":true}";
                else
                    data = "{ \"on\":false}";
                byte[] bytes;
                bytes = System.Text.Encoding.UTF8.GetBytes(data);
                string url = @"http://" + ip + "/api/" + username + "/lights/" + id + "/state";
                httpWebRequest.Method = "PUT";
                httpWebRequest.ContentLength = bytes.Length;
                Stream requestStream = httpWebRequest.GetRequestStream();
                requestStream.Write(bytes, 0, bytes.Length);
                requestStream.Close();
            catch (Exception ex)
                return false;
            return true;
ampoules_connectees_-_philips_hue_et_osram_ligthify.1520587412.txt.gz · Dernière modification : 2018/03/09 10:23 de 88.164.131.165 · Actuellement bloqué par : 181.134.207.3
