ampoules_connectees_-_philips_hue_et_osram_ligthify
Philips HUE et OSRAM Lightify
OSRAM Lightify
FAQ
Exemple application C#
Récupération d'un ticket
|Ticket
            //Le Token n'est valable que 15mn
            //user : le nom d'utilisateur de votre compte Osram
            //pass : votre mot de pass ....
            //serialnum : Le numéro de série qui apparait sur la passerelle OSR0xxxxxxx (Ne pas indiquer ce qui trouve apres le "-"
            OsramToken token = OsramController.GetOsramToken("user", "pass", "serialnum");
            textBoxToken.Text = token.securityToken;
            textBoxUserID.Text = token.userId;
|Class OsramToken
    public class OsramToken
        public string userId { get; set; }
        public string securityToken { get; set; }
|Class OsramController
    public class OsramController
        public static OsramToken GetOsramToken(string username, string password, string serialNumber)
            string payload = "{\"username\" : \"" + username + "\",\"password\" : \"" + password + "\",\"serialNumber\" : \"" + serialNumber + "\"}";
            string url = "https://eu.lightify-api.org/lightify/services/session";
            var httpWebRequest = (HttpWebRequest)WebRequest.Create(url);
            httpWebRequest.UserAgent = "Lightify/1.0.5 CFNetwork/711.1.16 Darwin/14.0.0";
            httpWebRequest.Method = "POST";
            httpWebRequest.ContentType = "application/json";
            using (var streamWriter = new StreamWriter(httpWebRequest.GetRequestStream()))
                streamWriter.Write(payload);
                streamWriter.Flush();
                streamWriter.Close();
            OsramToken os = new OsramToken();
            var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse();
            using (var streamReader = new StreamReader(httpResponse.GetResponseStream()))
                var result = streamReader.ReadToEnd();
                os = JsonConvert.DeserializeObject<OsramToken>(result);
            return os;
        public static List<OsramDevice> GetDevicesList(string token)
            List<OsramDevice> Devices = new List<OsramDevice>();
            string url = "https://eu.lightify-api.org/lightify/services/devices";
            httpWebRequest.Method = "GET";
            httpWebRequest.Headers.Add("authorization",token);
                Devices = JsonConvert.DeserializeObject<List<OsramDevice>>(result);
            return Devices;
        public static string SenCommand(string token, string cmd)
            string result = "";
            string url = "https://eu.lightify-api.org/lightify/services/"+cmd;
            httpWebRequest.Headers.Add("authorization", token);
            return result;
Récupération de la liste des équipements
|Devices
|Class Devices
    public class OsramDevice
        public int deviceId { get; set; }
        public string deviceType { get; set; }
        public string manufacturer { get; set; }
        public string modelName { get; set; }
        public string name { get; set; }
        public List<int> groupList { get; set; }
        public List<string> bmpClusters { get; set; }
        public bool online { get; set; }
        public bool on { get; set; }
        public float brightnessLevel { get; set; }
        public float hue { get; set; }
        public float saturation { get; set; }
        public int temperature { get; set; }
        public string firmwareVersion { get; set; }
        public string color { get; set; }
Envoi de commandes à un équipement
Toutes les commandes doivent faire référence à un ID d'équipement récupéré avec la liste des devices
|Class Devices
        private void buttonTurnOff_Click(object sender, EventArgs e)
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&time=" + numericUpDownTime.Value.ToString() + "&onoff=0");
        private void buttonTurnOn_Click(object sender, EventArgs e)
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&level=" + (numericUpDownLevel.Value / 100).ToString().Replace(",", ".") + "&time=" + numericUpDownTime.Value.ToString() + "&onoff=1");
        private void buttonChangeColor_Click(object sender, EventArgs e)
            string color = labelColor.Text.Replace("#", "");
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&time=" + numericUpDownTime.Value.ToString() + "&color="+labelColor.Text.Replace("#",""));
        private void buttonChangeLevel_Click(object sender, EventArgs e)
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&level=" + (numericUpDownLevel.Value / 100).ToString().Replace(",", ".") + "&time=" + numericUpDownTime.Value.ToString());
        private void buttonChangeTemperature_Click(object sender, EventArgs e)
            string result = OsramController.SenCommand(textBoxToken.Text, "device/set?idx=" + textBoxDeviceID.Text + "&time=" + numericUpDownTime.Value.ToString() + "&ctemp="+numericUpDownTemperature.Value.ToString());
Philips HUE
FAQ
ampoules_connectees_-_philips_hue_et_osram_ligthify.1478907309.txt.gz · Dernière modification : 2017/12/06 16:10 (modification externe) · Actuellement bloqué par : 216.73.216.94
