Philips HUE et OSRAM Lightify
OSRAM Lightify
FAQ
Exemple application C#
La documentation de l'API : https://eu.lightify-api.org/
Récupération d'un ticket
- |Ticket
//Le Token n'est valable que 15mn //user : le nom d'utilisateur de votre compte Osram //pass : votre mot de pass .... //serialnum : Le numéro de série qui apparait sur la passerelle OSR0xxxxxxx (Ne pas indiquer ce qui trouve apres le "-" OsramToken token = OsramController.GetOsramToken("user", "pass", "serialnum"); textBoxToken.Text = token.securityToken; textBoxUserID.Text = token.userId;
- |Class OsramToken
public class OsramToken { public string userId { get; set; } public string securityToken { get; set; } }
- |Class OsramController
public class OsramController { public static OsramToken GetOsramToken(string username, string password, string serialNumber) { string payload = "{\"username\" : \"" + username + "\",\"password\" : \"" + password + "\",\"serialNumber\" : \"" + serialNumber + "\"}"; string url = "https://eu.lightify-api.org/lightify/services/session"; var httpWebRequest = (HttpWebRequest)WebRequest.Create(url); httpWebRequest.UserAgent = "Lightify/1.0.5 CFNetwork/711.1.16 Darwin/14.0.0"; httpWebRequest.Method = "POST"; httpWebRequest.ContentType = "application/json"; using (var streamWriter = new StreamWriter(httpWebRequest.GetRequestStream())) { streamWriter.Write(payload); streamWriter.Flush(); streamWriter.Close(); } OsramToken os = new OsramToken(); var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse(); using (var streamReader = new StreamReader(httpResponse.GetResponseStream())) { var result = streamReader.ReadToEnd(); os = JsonConvert.DeserializeObject<OsramToken>(result); } return os; } public static List<OsramDevice> GetDevicesList(string token) { List<OsramDevice> Devices = new List<OsramDevice>(); string url = "https://eu.lightify-api.org/lightify/services/devices"; var httpWebRequest = (HttpWebRequest)WebRequest.Create(url); httpWebRequest.UserAgent = "Lightify/1.0.5 CFNetwork/711.1.16 Darwin/14.0.0"; httpWebRequest.Method = "GET"; httpWebRequest.ContentType = "application/json"; httpWebRequest.Headers.Add("authorization",token); var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse(); using (var streamReader = new StreamReader(httpResponse.GetResponseStream())) { var result = streamReader.ReadToEnd(); Devices = JsonConvert.DeserializeObject<List<OsramDevice>>(result); } return Devices; } public static string SenCommand(string token, string cmd) { string result = ""; string url = "https://eu.lightify-api.org/lightify/services/"+cmd; var httpWebRequest = (HttpWebRequest)WebRequest.Create(url); httpWebRequest.UserAgent = "Lightify/1.0.5 CFNetwork/711.1.16 Darwin/14.0.0"; httpWebRequest.Method = "GET"; httpWebRequest.ContentType = "application/json"; httpWebRequest.Headers.Add("authorization", token); var httpResponse = (HttpWebResponse)httpWebRequest.GetResponse(); using (var streamReader = new StreamReader(httpResponse.GetResponseStream())) { result = streamReader.ReadToEnd(); } return result; } }
Récupération de la liste des équipements
- |Devices
- |Class Devices
public class OsramDevice { public int deviceId { get; set; } public string deviceType { get; set; } public string manufacturer { get; set; } public string modelName { get; set; } public string name { get; set; } public List<int> groupList { get; set; } public List<string> bmpClusters { get; set; } public bool online { get; set; } public bool on { get; set; } public float brightnessLevel { get; set; } public float hue { get; set; } public float saturation { get; set; } public int temperature { get; set; } public string firmwareVersion { get; set; } public string color { get; set; } }
Philips HUE
FAQ
